Glass with label on the back
Hi there :slight_smile:
Not sure if this has already been discussed but the question is how to adjust the glass material so that the label placed on the back is visible through the glass and have the desired color??
Only a little is visible with the Glass(Solid) material.
If you need an example let me know but the only thing you need to do I think is to make sure you’ve the texture mapping as ‘planar’ and enter a very small number in the ‘depth’ which will basically prevent the planar mapped texture to exceed the depth so it’s also on the other side.
Thank you. It helped to enter a very small number in the “depth” field. I completely forgot about it.
